Possess Quest Demo (INDIE'D)
Forum for discussion about the INDIE'D showcase event.
Starturbo
Possess Quest Demo (Windows).zip
(5.8 MiB) Downloaded 3613 times
Possess Quest Demo (Linux).zip
(9.01 MiB) Downloaded 3675 times
Please note that this version of the game is outdated now!
Possess Quest is a puzzle platformer where you play as the enemies. It is currently quite early in development, though I figured I'd release a demo to give everyone a chance to play it in advance. It contains 1 world with 5 levels, and in addition, this new version of the demo includes some tweaks to the gameplay, level design, and visuals to hopefully make it feel more refined. So feel free to let me know what you think of these changes!
Game Instructions:
Travel through each level and run into enemies to swap to them. Try to be mindful of which enemy is required to progress and watch out for hazards!
Controllers should work with the game, although be aware X-Input ones are recommended and right now there's only button prompts for Keyboard, Xbox, and PlayStation controllers.
Pressing the R key (or the select button on a controller) will reset the current level, though be aware any retries will be included in the results at the end of the demo.
You can also press the S key (or the Y/Triangle button) to freely move the camera around. This can help with figuring out the best way to complete a level.
If you want a challenge, try to collect as many coins and golden bills as possible without dying or resetting as quickly as you can. Though how you play is up to you!
Use Alt+Enter (in the downloadable Windows version) or F11 (in the downloadable Linux version) to make the game fullscreen.
Enemy-specific abilities can be used by pressing either the Z key (A/Cross button), X Key (B/Circle button), or C key (X/Square button) while in the air.
Getting it Running:
Windows: Just unzip the game into its own directory and it should work. Ignore any warnings your OS or antivirus may throw at you, I promise it's safe!
Linux: On some versions of Ubuntu (or Linux in general) you may need to install the following dependencies in order to play the game:
libcurl4
libopenal1
You might also need to check "Allow executing file as program" under the game's Permissions (in the executable's Properties) in order to launch it.
Additionally, the game may not work on certain Linux versions and distros. There is little I can do about this, so please understand that.
Links:
You can visit here for my socials, where I post updates on my projects: https://linktr.ee/Starturbo
Links to my games on other sites can also be found there!
Screenshots:
Possess Quest Screenshot.png (23.53 KiB) Viewed 450154 times
Possess Quest Screenshot 2.png (25.64 KiB) Viewed 450154 times
Possess Quest Screenshot 3.png (20.37 KiB) Viewed 450154 times
Possess Quest Screenshot 4.png (25.89 KiB) Viewed 450154 times
Possess Quest Screenshot 5.png (22.82 KiB) Viewed 450154 times
Just an artist and developer making indie games and other projects
https://starturbo.carrd.co
